Giriş
Follow this guide in order to uninstall the bluetooth chip in your device, the follow it in reverse order to install the new one.
The bluetooth chip is necessary for you to be able to access to bluetooth capability of your device. Bluetooth allows you to connect to other devices wirelessly and without it, these devices cannot connect.
Neye ihtiyacın var
On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
Unscrew the 4 10mm Philips J1 screws beneath them.
Using your fingers, lightly pull on the white connector shown in the photo.
Unscrew the 10mm Philips J1 Screw from the guard above the bluetooth chip.
