Giriş
This guide will show you how to disassemble the unit, which is universally the first step to starting all of the repair guides. The faceplate it the only thing in the way between you and the internal parts of the device. Without the faceplate on, you can repair literally anything in the device.
Neye ihtiyacın var
On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
Unscrew the 4 10mm Philips J1 screws beneath them.
Bir başkası bu kılavuzu tamamladı.
