Ana içeriğe geç
Sony SRS-XB30 Bluetooth Chip Replacement
Neye ihtiyacın var
  1. Sony SRS-XB30 Bluetooth Chip Replacement, Battery: adım 1, 1 resimden 1.
    • To remove the speaker grill, insert the big spudger underneath it in each corner.
    • Work around the edges to pry the grill up and off.
  2. Sony SRS-XB30 Bluetooth Chip Replacement: adım 2, 2 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 2, 2 resimden 2.
    • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
    • This will need to be done on all four sides of the speaker to remove all four panels
    • This requires some effort because the adhesive is sticky.
  3. Sony SRS-XB30 Bluetooth Chip Replacement: adım 3, 2 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 3, 2 resimden 2.
    • Locate the four screws on the now exposed front panel.
    • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
  4. Sony SRS-XB30 Bluetooth Chip Replacement: adım 4, 1 resimden 1.
    • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
    • Use the same T7 screwdriver head here.
    • Remove each of the four corner screws (15.0 mm long).
  5. Sony SRS-XB30 Bluetooth Chip Replacement: adım 5, 1 resimden 1.
    • With a little force, carefully lift the lid of the speaker.
    • Make sure that you do not pull on the wires.
  6. Sony SRS-XB30 Bluetooth Chip Replacement: adım 6, 3 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 6, 3 resimden 2. Sony SRS-XB30 Bluetooth Chip Replacement: adım 6, 3 resimden 3.
    • Unclip the four wire connectors (that are attached to the speaker lid).
    • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
  7. Sony SRS-XB30 Bluetooth Chip Replacement: adım 7, 1 resimden 1.
    • Separate the speaker lid from the bottom frame.
    • To prepare the speaker for the next step place the lid parallel to the frame.
  8. Sony SRS-XB30 Bluetooth Chip Replacement: adım 8, 1 resimden 1.
    • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
    • Using the screwdriver with bit PH1, unscrew each screw.
  9. Sony SRS-XB30 Bluetooth Chip Replacement: adım 9, 1 resimden 1.
    • Separate the speaker lid entirely from the bottom frame.
  10. Sony SRS-XB30 Bluetooth Chip Replacement: adım 10, 1 resimden 1.
    • Remove the top screw (10 mm).
    • Use the screwdriver with bit T7.
  11. Sony SRS-XB30 Bluetooth Chip Replacement: adım 11, 2 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 11, 2 resimden 2.
    • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
    • There are two screws on the left side of the white box and one to its right.
  12. Sony SRS-XB30 Bluetooth Chip Replacement: adım 12, 1 resimden 1.
    • Slightly lift the white box with all the wires still attached.
  13. Sony SRS-XB30 Bluetooth Chip Replacement: adım 13, 2 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 13, 2 resimden 2.
    • Take the big spudger and pry the black casing up from the circuit box.
  14. Sony SRS-XB30 Bluetooth Chip Replacement: adım 14, 1 resimden 1.
    • Locate the blue film attached to the circuit box containing the charging port.
    • Detach the blue film from the box.
  15. Sony SRS-XB30 Bluetooth Chip Replacement: adım 15, 1 resimden 1.
    • Detach the yellow, black and red wires by pulling them directly up.
  16. Sony SRS-XB30 Bluetooth Chip Replacement: adım 16, 2 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 16, 2 resimden 2.
    • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
  17. Sony SRS-XB30 Bluetooth Chip Replacement, Bluetooth Chip: adım 17, 1 resimden 1.
    • To save time, pry up and remove the top panel first.
  18. Sony SRS-XB30 Bluetooth Chip Replacement: adım 18, 2 resimden 1. Sony SRS-XB30 Bluetooth Chip Replacement: adım 18, 2 resimden 2.
    • Take the spudger and pry under the plastic square that the Bluetooth chip is directly attached to.
    • This will separate the plastic square from the lid.
  19. Sony SRS-XB30 Bluetooth Chip Replacement: adım 19, 1 resimden 1.
    • Remove the Bluetooth chip.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I'm pretty sure this is the nfc chip and not the Bluetooth chip
john may - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 3,543
