Ana içeriğe geç
Sony SRS-XE200 Battery Replacement
Neye ihtiyacın var
  1. Sony SRS-XE200 Battery Replacement, Speaker Assembly: adım 1, 2 resimden 1. Sony SRS-XE200 Battery Replacement, Speaker Assembly: adım 1, 2 resimden 2.
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Battery Replacement: adım 2, 1 resimden 1.
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Battery Replacement: adım 3, 2 resimden 1. Sony SRS-XE200 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Battery Replacement: adım 4, 2 resimden 1. Sony SRS-XE200 Battery Replacement: adım 4, 2 resimden 2.
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Battery Replacement, Battery: adım 5, 3 resimden 1. Sony SRS-XE200 Battery Replacement, Battery: adım 5, 3 resimden 2. Sony SRS-XE200 Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Battery Replacement: adım 6, 3 resimden 1. Sony SRS-XE200 Battery Replacement: adım 6, 3 resimden 2. Sony SRS-XE200 Battery Replacement: adım 6, 3 resimden 3.
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Thanks what is the replacement battery number?
fred Pope - Yanıt
What is the battery number for the SRS replacement
fred Pope - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 611
