Ana içeriğe geç
Sony SRS-XE200 Microphone Replacement
Neye ihtiyacın var
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: adım 1, 2 resimden 1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: adım 1, 2 resimden 2.
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Microphone Replacement: adım 2, 1 resimden 1.
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Microphone Replacement: adım 3, 2 resimden 1. Sony SRS-XE200 Microphone Replacement: adım 3, 2 resimden 2.
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Microphone Replacement: adım 4, 2 resimden 1. Sony SRS-XE200 Microphone Replacement: adım 4, 2 resimden 2.
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Microphone Replacement, Battery: adım 5, 3 resimden 1. Sony SRS-XE200 Microphone Replacement, Battery: adım 5, 3 resimden 2. Sony SRS-XE200 Microphone Replacement, Battery: adım 5, 3 resimden 3.
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Microphone Replacement: adım 6, 3 resimden 1. Sony SRS-XE200 Microphone Replacement: adım 6, 3 resimden 2. Sony SRS-XE200 Microphone Replacement: adım 6, 3 resimden 3.
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: adım 7, 2 resimden 1. Sony SRS-XE200 Microphone Replacement, Charging Port: adım 7, 2 resimden 2.
    • Remove the charging port.
  8. Sony SRS-XE200 Microphone Replacement, Microphone: adım 8, 3 resimden 1. Sony SRS-XE200 Microphone Replacement, Microphone: adım 8, 3 resimden 2. Sony SRS-XE200 Microphone Replacement, Microphone: adım 8, 3 resimden 3.
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
  9. Sony SRS-XE200 Microphone Replacement: adım 9, 1 resimden 1.
  10. Sony SRS-XE200 Microphone Replacement: adım 10, 2 resimden 1. Sony SRS-XE200 Microphone Replacement: adım 10, 2 resimden 2.
  11. Sony SRS-XE200 Microphone Replacement: adım 11, 3 resimden 1. Sony SRS-XE200 Microphone Replacement: adım 11, 3 resimden 2. Sony SRS-XE200 Microphone Replacement: adım 11, 3 resimden 3.
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 206
