Ana içeriğe geç
Sony SRS-XE200 Motherboard Replacement
Neye ihtiyacın var
  1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: adım 1, 2 resimden 1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: adım 1, 2 resimden 2.
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Motherboard Replacement: adım 3, 2 resimden 1. Sony SRS-XE200 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Motherboard Replacement: adım 4, 2 resimden 1. Sony SRS-XE200 Motherboard Replacement: adım 4, 2 resimden 2.
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Sony SRS-XE200 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Sony SRS-XE200 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the cord connecting the charging port to the motherboard.
  7. Sony SRS-XE200 Motherboard Replacement: adım 7, 3 resimden 1. Sony SRS-XE200 Motherboard Replacement: adım 7, 3 resimden 2. Sony SRS-XE200 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the two 0.8 mm screws attaching the motherboard to the case compartment with a Phillips #1 screwdriver.
    • Detach the motherboard from the case compartment.
Sonuç
Bir Yorum
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
Abdou Abdou - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 362
