Ana içeriğe geç
Sony SRS-XE200 Speaker Assembly Replacement
Neye ihtiyacın var
  1. Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: adım 1, 2 resimden 1. Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: adım 1, 2 resimden 2.
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Speaker Assembly Replacement: adım 2, 1 resimden 1.
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Speaker Assembly Replacement: adım 3, 2 resimden 1. Sony SRS-XE200 Speaker Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Speaker Assembly Replacement: adım 4, 2 resimden 1. Sony SRS-XE200 Speaker Assembly Replacement: adım 4, 2 resimden 2.
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
Sonuç
Kristen Gismondi
82.695 İtibar
202 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.420 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 140
