Ana içeriğe geç
Sony SS-CCP1 Speaker Replacement
Neye ihtiyacın var
  1. Sony SS-CCP1 Speaker Replacement, Screen: adım 1, 3 resimden 1. Sony SS-CCP1 Speaker Replacement, Screen: adım 1, 3 resimden 2. Sony SS-CCP1 Speaker Replacement, Screen: adım 1, 3 resimden 3.
    • Pull screen cover from the edges for removal. This will not require much effort.
  2. Sony SS-CCP1 Speaker Replacement, Speaker: adım 2, 2 resimden 1. Sony SS-CCP1 Speaker Replacement, Speaker: adım 2, 2 resimden 2.
    • Remove the seven 18.06mm PH1 screws.
  3. Sony SS-CCP1 Speaker Replacement: adım 3, 3 resimden 1. Sony SS-CCP1 Speaker Replacement: adım 3, 3 resimden 2. Sony SS-CCP1 Speaker Replacement: adım 3, 3 resimden 3.
    • Remove the crimps from the tweeter speaker.
    • If its not connected too tightly the crimps can be removed by hand pressure only.
    • If its too tight to be removed by hand, then you can use a pair of pliers to removed the crimps.
    • Never remove by pulling on the cables. Always pull by the metal crimps.
  4. Sony SS-CCP1 Speaker Replacement: adım 4, 3 resimden 1. Sony SS-CCP1 Speaker Replacement: adım 4, 3 resimden 2. Sony SS-CCP1 Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the crimps from the 12cm loudspeaker.
  5. Sony SS-CCP1 Speaker Replacement: adım 5, 2 resimden 1. Sony SS-CCP1 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the grommet using an object with a flat edge.
    • The grommet is not made of rubber, it is made of plastic. Be careful when removing it, as it can break easily.
  6. Sony SS-CCP1 Speaker Replacement: adım 6, 2 resimden 1. Sony SS-CCP1 Speaker Replacement: adım 6, 2 resimden 2.
    • Feed the speaker cable through the front of the box.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Dallas
892 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Baechle Fall 2016 IUPUI, Team 3-2, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 40
Her zaman: 3,869
