Ana içeriğe geç
Sony TCM-919 Cassette-Corder Microphone Replacement
Neye ihtiyacın var
  1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove battery Cover: adım 1, 1 resimden 1.
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Back Casing: adım 2, 1 resimden 1.
    • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
  3. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: adım 3, 2 resimden 1. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: adım 3, 2 resimden 2.
    • Look to the back of the top cover.
    • Desolder the two wires connected to the mircophone using the soldering station.
  4. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: adım 4, 2 resimden 1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: adım 4, 2 resimden 2.
    • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
    • Remove the microphone by pulling up.
Sonuç
Marygayle Martin
506 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 503
