Ana içeriğe geç
Sony TCM-919 Cassette-Corder Motherboard Replacement
Neye ihtiyacın var
  1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Back Cover: adım 1, 1 resimden 1.
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Motherboard Replacement, Back Cover Screw Removal: adım 2, 1 resimden 1.
    • Remove the 5 5.95mm screws as indicated in the picture using the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: adım 3, 2 resimden 1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: adım 3, 2 resimden 2.
    • Locate the 3-digit tape counter and gently push the tabs apart releasing the counter.
    • Pull the 3-digit tape counter out.
    • Remove the rubber band attaching the 3-digit tape counter to the cassette head.
  4. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: adım 4, 2 resimden 1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: adım 4, 2 resimden 2.
    • Remove the screws as indicated in the picture using the Phillips Head screwdriver.
    • Pull the loosened motor out of the device, and set the motor aside.
  5. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: adım 5, 3 resimden 1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: adım 5, 3 resimden 2. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: adım 5, 3 resimden 3.
    • Removes the 3, 5.95mm screws using the Phillips Head screwdriver as indicated by picture 1.
    • Push firmly on the tabs and lift the tape deck out.
    • Set the tape deck aside.
  6. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motherboard Screws: adım 6, 1 resimden 1.
    • Remove the 2 5.95mm screws as indicated by the picture using the Phillips Head screwdriver.
  7. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Epoxy: adım 7, 1 resimden 1.
    • Remove the epoxy completely from the motherboard so that the wires underneath the epoxy can move freely.
  8. Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: adım 8, 2 resimden 1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: adım 8, 2 resimden 2.
    • Remove the motherboard from case.
    • Flip the motherboard around so that the metallic green side is facing you.
    • Desolder the points indicated in picture 2. This should free the wires connected to the motherboard.
    • Remove the motherboard by pulling it out of the device cavity.
Sonuç
Marygayle Martin
506 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 1,730
