Ana içeriğe geç
Sony VAIO VPCEE26FX Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: adım 2, 2 resimden 1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: adım 2, 2 resimden 2.
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: adım 3, 2 resimden 1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: adım 3, 2 resimden 2.
    • Using a JIS #0 screwdriver, remove the two 4mm screws securing the hard drive cover to the laptop.
    • Lift the hard drive up and out of its place.
    • The drive cover and hard drive are not pictured. They are both missing from this particular device.
Sonuç
Christopher Hover
679 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,729
