Ana içeriğe geç
Sony VAIO VPCEE26FX Keyboard Replacement
Neye ihtiyacın var
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: adım 2, 2 resimden 1. Sony VAIO VPCEE26FX Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: adım 4, 1 resimden 1.
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: adım 5, 2 resimden 1. Sony VAIO VPCEE26FX Keyboard Replacement: adım 5, 2 resimden 2.
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: adım 6, 2 resimden 1. Sony VAIO VPCEE26FX Keyboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: adım 7, 1 resimden 1.
  8. Sony VAIO VPCEE26FX Keyboard Replacement: adım 8, 1 resimden 1.
    • Lift the keyboard up and away from the computer.
Sonuç
Christopher Hover
679 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,170
