Ana içeriğe geç
Sony VAIO VPCEE26FX RAM Replacement
Neye ihtiyacın var
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPCEE26FX RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: adım 2, 2 resimden 1. Sony VAIO VPCEE26FX RAM Replacement: adım 2, 2 resimden 2.
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: adım 4, 1 resimden 1.
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: adım 5, 3 resimden 1. Sony VAIO VPCEE26FX RAM Replacement: adım 5, 3 resimden 2. Sony VAIO VPCEE26FX RAM Replacement: adım 5, 3 resimden 3.
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: adım 6, 3 resimden 1. Sony VAIO VPCEE26FX RAM Replacement: adım 6, 3 resimden 2. Sony VAIO VPCEE26FX RAM Replacement: adım 6, 3 resimden 3.
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
Sonuç
Christopher Hover
679 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,377
