Ana içeriğe geç
Sony VAIO VPCEC1M1E Keyboard Replacement
Neye ihtiyacın var
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: adım 3, 1 resimden 1.
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: adım 4, 3 resimden 1. Sony VAIO VPCEC1M1E Keyboard Replacement: adım 4, 3 resimden 2. Sony VAIO VPCEC1M1E Keyboard Replacement: adım 4, 3 resimden 3.
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Stephan
199 İtibar
1 Kılavuz yazıldı
3 Yorum
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - Yanıt
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - Yanıt
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 23,004
