Ana içeriğe geç
Sony VAIO PCG-933A Battery Replacement
  1. Sony VAIO PCG-933A Battery Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO PCG-933A Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Battery Replacement: adım 2, 3 resimden 1. Sony VAIO PCG-933A Battery Replacement: adım 2, 3 resimden 2. Sony VAIO PCG-933A Battery Replacement: adım 2, 3 resimden 3.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
Sonuç
Sara Lillard
165 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G36
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,558
