Ana içeriğe geç
Sony VAIO PCG-933A Fan Replacement
Neye ihtiyacın var
    1. Sony VAIO PCG-933A Fan Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO PCG-933A Fan Replacement, Battery: adım 1, 2 resimden 2.
      • Turn the laptop upside down so that the top is sitting on a flat surface.
      • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
      FixBot'a Sor
      Yorum Ekle
    2. Sony VAIO PCG-933A Fan Replacement: adım 2, 3 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 2, 3 resimden 2. Sony VAIO PCG-933A Fan Replacement: adım 2, 3 resimden 3.
      • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
      • You should now be able to pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. Sony VAIO PCG-933A Fan Replacement, Keyboard: adım 3, 1 resimden 1.
      • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Sony VAIO PCG-933A Fan Replacement: adım 4, 2 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 4, 2 resimden 2.
      • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
      • This will release the speaker grille.
      FixBot'a Sor
      Yorum Ekle
    3. Sony VAIO PCG-933A Fan Replacement: adım 5, 1 resimden 1.
      • Flip the computer so the key board is facing up.
      FixBot'a Sor
      Yorum Ekle
    4. Sony VAIO PCG-933A Fan Replacement: adım 6, 3 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 6, 3 resimden 2. Sony VAIO PCG-933A Fan Replacement: adım 6, 3 resimden 3.
      • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
      • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
      FixBot'a Sor
      Yorum Ekle
    5. Sony VAIO PCG-933A Fan Replacement: adım 7, 3 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 7, 3 resimden 2. Sony VAIO PCG-933A Fan Replacement: adım 7, 3 resimden 3.
      • Remove the 4mm screw in the center using a Phillips screwdriver.
      • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
      • The keyboard can now be removed.
      FixBot'a Sor
      Yorum Ekle
    1. Sony VAIO PCG-933A Fan Replacement, Fan: adım 8, 3 resimden 1. Sony VAIO PCG-933A Fan Replacement, Fan: adım 8, 3 resimden 2. Sony VAIO PCG-933A Fan Replacement, Fan: adım 8, 3 resimden 3.
      • Remove the four 4mm Phillips screws around the hard drive.
      • WARNING: DVD drive is now loose as well
      • Carefully lift the hard drive cage out.
      • Carefully disconnect the copper strip to pull out the hard drive.
      FixBot'a Sor
      Yorum Ekle
    2. Sony VAIO PCG-933A Fan Replacement: adım 9, 2 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 9, 2 resimden 2.
      • With the hard drive removed, unscrew the four 6mm brass colored, Phillips screws under the hard drive cage.
      • This will allow you to remove the hard drive mounting bracket.
      FixBot'a Sor
      Yorum Ekle
    3. Sony VAIO PCG-933A Fan Replacement: adım 10, 1 resimden 1.
      • Remove the three 6mm brass colored, Phillips screws that hold the fan cage in place.
      FixBot'a Sor
      Yorum Ekle
    4. Sony VAIO PCG-933A Fan Replacement: adım 11, 2 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 11, 2 resimden 2.
      • Remove the two 4mm black, Phillips screws shown here.
      • Remove the 18mm silver, Phillips screw shown here.
      • Now remove the silver tab.
      FixBot'a Sor
      Yorum Ekle
    5. Sony VAIO PCG-933A Fan Replacement: adım 12, 2 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 12, 2 resimden 2.
      • Remove the blue and red fan power cords.
      FixBot'a Sor
      Yorum Ekle
    6. Sony VAIO PCG-933A Fan Replacement: adım 13, 2 resimden 1. Sony VAIO PCG-933A Fan Replacement: adım 13, 2 resimden 2.
      • Carefully pull up and out on the metal heat sink and fan bracket.
      • The fan can now be cleaned or replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sara Lillard
165 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G36
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 2,864
