Ana içeriğe geç
Sony VAIO PCG-933A Floppy Disk Drive Replacement
  1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 2, 3 resimden 1. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 2, 3 resimden 2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 2, 3 resimden 3.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Floppy Disk Drive: adım 3, 1 resimden 1.
    • With the laptop facing you, turn the laptop upside down.
  4. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 4, 3 resimden 1. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 4, 3 resimden 2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 4, 3 resimden 3.
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  5. Sony VAIO PCG-933A Floppy Disk Drive Replacement: adım 5, 1 resimden 1.
    • To replace, insert the new floppy disk drive with the wording facing down.
Sonuç
Sara Lillard
165 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G36
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 2,021
