Ana içeriğe geç
Sony VAIO PCG-933A Keyboard Replacement
Neye ihtiyacın var
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO PCG-933A Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    FixBot'a Sor
    Yorum Ekle
  2. Sony VAIO PCG-933A Keyboard Replacement: adım 2, 3 resimden 1. Sony VAIO PCG-933A Keyboard Replacement: adım 2, 3 resimden 2. Sony VAIO PCG-933A Keyboard Replacement: adım 2, 3 resimden 3.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Sony VAIO PCG-933A Keyboard Replacement: adım 4, 2 resimden 1. Sony VAIO PCG-933A Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
    FixBot'a Sor
    Yorum Ekle
  5. Sony VAIO PCG-933A Keyboard Replacement: adım 5, 1 resimden 1.
    • Flip the computer so the key board is facing up.
    FixBot'a Sor
    Yorum Ekle
  6. Sony VAIO PCG-933A Keyboard Replacement: adım 6, 3 resimden 1. Sony VAIO PCG-933A Keyboard Replacement: adım 6, 3 resimden 2. Sony VAIO PCG-933A Keyboard Replacement: adım 6, 3 resimden 3.
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
    FixBot'a Sor
    Yorum Ekle
  7. Sony VAIO PCG-933A Keyboard Replacement: adım 7, 3 resimden 1. Sony VAIO PCG-933A Keyboard Replacement: adım 7, 3 resimden 2. Sony VAIO PCG-933A Keyboard Replacement: adım 7, 3 resimden 3.
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Sara Lillard
165 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G36
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 2,239
