Ana içeriğe geç
Sony VAIO PCG-933A RAM Replacement
Neye ihtiyacın var
  1. Sony VAIO PCG-933A RAM Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO PCG-933A RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A RAM Replacement: adım 2, 3 resimden 1. Sony VAIO PCG-933A RAM Replacement: adım 2, 3 resimden 2. Sony VAIO PCG-933A RAM Replacement: adım 2, 3 resimden 3.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A RAM Replacement, RAM: adım 3, 1 resimden 1.
    • With the laptop facing you, flip the laptop upside down.
  4. Sony VAIO PCG-933A RAM Replacement: adım 4, 3 resimden 1. Sony VAIO PCG-933A RAM Replacement: adım 4, 3 resimden 2. Sony VAIO PCG-933A RAM Replacement: adım 4, 3 resimden 3.
    • Remove the 4mm Phillips screw that holds the small panel in the center of the laptop in place.
    • Then remove the panel covering the RAM.
    • The RAM should now be visible.
  5. Sony VAIO PCG-933A RAM Replacement: adım 5, 3 resimden 1. Sony VAIO PCG-933A RAM Replacement: adım 5, 3 resimden 2. Sony VAIO PCG-933A RAM Replacement: adım 5, 3 resimden 3.
    • Release the plastic switches on each side of the stick of RAM.
    • Carefully slide the stick of RAM out at an angle.
    • DO NOT FORCE OUT.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sara Lillard
165 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G36
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 1,937
