Ana içeriğe geç
Sony VAIO PCG-F360 Single Key Replacement
Neye ihtiyacın var
  1. Sony VAIO PCG-F360 Single Key Replacement, Battery: adım 1, 1 resimden 1.
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
    FixBot'a Sor
    Yorum Ekle
  2. Sony VAIO PCG-F360 Single Key Replacement: adım 2, 1 resimden 1.
    • Lift the panel up and then out to gain access to the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Sony VAIO PCG-F360 Single Key Replacement: adım 3, 1 resimden 1.
    • Use the indentations to pull the old battery out.
    FixBot'a Sor
    Yorum Ekle
  4. Sony VAIO PCG-F360 Single Key Replacement: adım 4, 1 resimden 1.
    • The battery is now removed and it is safe to move on to uninstalling other components.
    FixBot'a Sor
    Yorum Ekle
  5. Sony VAIO PCG-F360 Single Key Replacement, Single Key: adım 5, 3 resimden 1. Sony VAIO PCG-F360 Single Key Replacement, Single Key: adım 5, 3 resimden 2. Sony VAIO PCG-F360 Single Key Replacement, Single Key: adım 5, 3 resimden 3.
    • Use the pludger to pop off the key by prying under it.
    • You now can clean and replace the key.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Hannah Millea
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G5
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 515
