Ana içeriğe geç
Sony VAIO PCG-F360 Speaker Panel Replacement
Neye ihtiyacın var
  1. Sony VAIO PCG-F360 Speaker Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Panel Replacement: adım 2, 1 resimden 1.
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Panel Replacement: adım 3, 1 resimden 1.
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Panel Replacement: adım 4, 1 resimden 1.
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: adım 5, 3 resimden 1. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: adım 5, 3 resimden 2. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: adım 5, 3 resimden 3.
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Panel Replacement: adım 6, 3 resimden 1. Sony VAIO PCG-F360 Speaker Panel Replacement: adım 6, 3 resimden 2. Sony VAIO PCG-F360 Speaker Panel Replacement: adım 6, 3 resimden 3.
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
Sonuç
Hannah Millea
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 158
