Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Position the laptop screen-side down as shown.
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Lift the panel up and then out to gain access to the battery.
    • Lift the panel up and then out to gain access to the battery.
  3. Use the indentations to pull the old battery out.
    • Use the indentations to pull the old battery out.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  5. The battery is now removed and it is safe to move on to uninstalling other components.
    • The battery is now removed and it is safe to move on to uninstalling other components.
  6. There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver. Slide the speaker panel towards the left, then carefully flip it over onto the keyboard. Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  7. Push the beige tab in the direction of the ribbon. it should only move a small amount Remove the ribbon by gently pulling on it, there should be little or no resistance. Now the speaker panel can be set aside.
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  8. The two speakers are located on the ends of the panel. There are two screws holding each speaker. Remove them using a #00 Philips head screw driver.
    • The two speakers are located on the ends of the panel.
    • There are two screws holding each speaker. Remove them using a #00 Philips head screw driver.
  9. Carefully flip the speaker over and replace or clean the needed parts.
    • Carefully flip the speaker over and replace or clean the needed parts.
Sonuç
Hannah Millea
401 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 91
