Giriş
Replacement steps for a hard disk drive in a Sony VAIO SVE14AJ16L Laptop.
Parçalar
Hiçbir parçaya gerek yok.
  1. Turn off your laptop before starting.
    • Turn off your laptop before starting.
    • Turn the closed laptop upside down so that the bottom is facing you.
  2. Locate and remove the two Phillips #0 screws on the hard drive cover with the screw driver. Then remove the hard drive cover.
    • Locate and remove the two Phillips #0 screws on the hard drive cover with the screw driver.
    • Then remove the hard drive cover.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Locate and remove the two Phillips #0 screws holding the hard drive in place Using the plastic tab, slide the hard drive out away from the main portion of the laptop. Lift the hard drive out of the laptop using the tab.
    • Locate and remove the two Phillips #0 screws holding the hard drive in place
    • Using the plastic tab, slide the hard drive out away from the main portion of the laptop.
    • Lift the hard drive out of the laptop using the tab.
  5. Finally, remove the 4 Phillips #0 screws holding the hard drive bracket to the hard drive. Finally, remove the 4 Phillips #0 screws holding the hard drive bracket to the hard drive. Finally, remove the 4 Phillips #0 screws holding the hard drive bracket to the hard drive.
    • Finally, remove the 4 Phillips #0 screws holding the hard drive bracket to the hard drive.
Sonuç
Dustin Smith
218 İtibar
2 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 7
Son 30 Gün: 9
Her zaman: 65
