Ana içeriğe geç
Sony VAIO SVE14AJ16L RAM Replacement
Neye ihtiyacın var
  1. Sony VAIO SVE14AJ16L RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Turn your laptop off before starting.
    • Turn the laptop upside down onto the closed lid so that the bottom is facing you.
  2. Sony VAIO SVE14AJ16L RAM Replacement: adım 2, 2 resimden 1. Sony VAIO SVE14AJ16L RAM Replacement: adım 2, 2 resimden 2.
    • Locate and remove the lone screw on the RAM cover with a Phillips #0 head screw driver.
    • Carefully pry the RAM cover up.
    • There will be some resistance, so use strength and not speed to remove the cover.
  3. Sony VAIO SVE14AJ16L RAM Replacement: adım 3, 3 resimden 1. Sony VAIO SVE14AJ16L RAM Replacement: adım 3, 3 resimden 2. Sony VAIO SVE14AJ16L RAM Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    Satın Al
    • With the cover removed, peel back the black protective plastic to expose one of the two RAM sticks.
    • Make sure not to touch any part of the blue board itself, and only handle the stick from it's edges.
    • Gently, but firmly push back the two side anchors that hold in the RAM using either an iFixit Opening Tool or your fingernails.
  4. Sony VAIO SVE14AJ16L RAM Replacement: adım 4, 2 resimden 1. Sony VAIO SVE14AJ16L RAM Replacement: adım 4, 2 resimden 2.
    • Once both anchors are released from the RAM stick, the stick will spring up at an angle
    • Finally, carefully pull the RAM stick away from the laptop at the same angle it is sitting at.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 535
