Ana içeriğe geç
Sony VAIO VPC-EB33FM Display Replacement
Neye ihtiyacın var
  1. Sony VAIO VPC-EB33FM Display Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement, Battery: adım 1, 2 resimden 2.
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
    FixBot'a Sor
    Yorum Ekle
  2. Sony VAIO VPC-EB33FM Display Replacement: adım 2, 1 resimden 1.
    • To release the battery, hold both the release button and the unlock button at the same time.
    FixBot'a Sor
    Yorum Ekle
  3. Sony VAIO VPC-EB33FM Display Replacement: adım 3, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 3, 2 resimden 2.
    • Remove the battery out from the notch while continuing to hold the release button.
    FixBot'a Sor
    Yorum Ekle
  4. Sony VAIO VPC-EB33FM Display Replacement, Hard Drive: adım 4, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement, Hard Drive: adım 4, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
    FixBot'a Sor
    Yorum Ekle
  5. Sony VAIO VPC-EB33FM Display Replacement: adım 5, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 5, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement: adım 5, 3 resimden 3.
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
    FixBot'a Sor
    Yorum Ekle
  6. Sony VAIO VPC-EB33FM Display Replacement: adım 6, 1 resimden 1.
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Sony VAIO VPC-EB33FM Display Replacement: adım 7, 1 resimden 1.
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
    FixBot'a Sor
    Yorum Ekle
  8. Sony VAIO VPC-EB33FM Display Replacement: adım 8, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 8, 2 resimden 2.
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
    FixBot'a Sor
    Yorum Ekle
  9. Sony VAIO VPC-EB33FM Display Replacement: adım 9, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 9, 2 resimden 2.
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
    FixBot'a Sor
    Yorum Ekle
  10. Sony VAIO VPC-EB33FM Display Replacement, RAM: adım 10, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement, RAM: adım 10, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement, RAM: adım 10, 3 resimden 3.
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
    FixBot'a Sor
    Yorum Ekle
  11. Sony VAIO VPC-EB33FM Display Replacement: adım 11, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 11, 2 resimden 2.
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
    FixBot'a Sor
    Yorum Ekle
  12. Sony VAIO VPC-EB33FM Display Replacement: adım 12, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 12, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement: adım 12, 3 resimden 3.
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
    FixBot'a Sor
    Yorum Ekle
  13. Sony VAIO VPC-EB33FM Display Replacement, Keyboard: adım 13, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove the following screws securing the back cover :
    • Two 3.8-mm screws
    • Two 8.9-mm screws
    • Twelve 7.75-mm screws
    FixBot'a Sor
    Yorum Ekle
  14. Sony VAIO VPC-EB33FM Display Replacement: adım 14, 1 resimden 1.
    • Check to make sure all screws have been removed.
    • Using both hands separate the back cover by lifting from the back and working around the perimeter to release tabs.
    FixBot'a Sor
    Yorum Ekle
  15. Sony VAIO VPC-EB33FM Display Replacement: adım 15, 1 resimden 1.
    • Uninstalling the keyboard may require a second set of hands.
    • During the removal of the back cover, a screw that attaches the optical drive to the laptop is also taken out. This means the optical drive is ready to be removed.
    • Remove the optical drive by sliding it out.
    FixBot'a Sor
    Yorum Ekle
  16. Sony VAIO VPC-EB33FM Display Replacement: adım 16, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 16, 2 resimden 2.
    • Once the optical drive is removed, locate the keyboard ejection button and press down on it until you hear a snap.
    • Once you hear this sound, it means that a section of the keyboard has been ejected.
    FixBot'a Sor
    Yorum Ekle
  17. Sony VAIO VPC-EB33FM Display Replacement: adım 17, 1 resimden 1.
    • Turn the laptop onto its frontside and unfold the laptop so the keyboard is fully visible.
    • Locate the area where the section of the keyboard was ejected.
    FixBot'a Sor
    Yorum Ekle
  18. Sony VAIO VPC-EB33FM Display Replacement: adım 18, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 18, 2 resimden 2.
    • Start to pry out the keyboard with your hands.
    • Be careful not to break any of the hooks that attach the keyboard to the laptop.
    • If it seems difficult to remove the keyboard with your hands, then use a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  19. Sony VAIO VPC-EB33FM Display Replacement: adım 19, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 19, 2 resimden 2.
    • Remain cautious to not break the hooks.
    • Continue all the way around the keyboard until you can detach it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  20. Sony VAIO VPC-EB33FM Display Replacement: adım 20, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 20, 2 resimden 2.
    • Do not immediately pull the keyboard away from the laptop. There is still an attachment between the keyboard and laptop.
    • Turn the keyboard on its face and locate the green tape and the ribbon attachment.
    • Using the metal tweezer, remove only the green sticker.
    • Place the sticker at any location as long as you remember to use it for installing the keyboard.
    FixBot'a Sor
    Yorum Ekle
  21. Sony VAIO VPC-EB33FM Display Replacement: adım 21, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 21, 2 resimden 2.
    • Locate the black retaining arms.
    • Using the plastic opening tool, pull the retaining arms out.
    • The retaining arms will not come off completely.
    FixBot'a Sor
    Yorum Ekle
  22. Sony VAIO VPC-EB33FM Display Replacement: adım 22, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 22, 2 resimden 2.
    • It is safe to touch the ribbon attachment.
    • Lift the retaining arms with the plastic opening tool at an angle so that the ribbon attachment can be pulled out.
    FixBot'a Sor
    Yorum Ekle
  23. Sony VAIO VPC-EB33FM Display Replacement, Display: adım 23, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 8.88-mm screws attached to the metal hinge at the corner of the laptop.
    • Repeat for the three screws on the opposite corner.
    FixBot'a Sor
    Yorum Ekle
  24. Sony VAIO VPC-EB33FM Display Replacement: adım 24, 1 resimden 1.
    • Lift the metal hinges on each corner to a 90º angle.
    FixBot'a Sor
    Yorum Ekle
  25. Sony VAIO VPC-EB33FM Display Replacement: adım 25, 1 resimden 1.
    • Gently pull out the base and place it with the keyboard side up under the display.
    FixBot'a Sor
    Yorum Ekle
  26. Sony VAIO VPC-EB33FM Display Replacement: adım 26, 1 resimden 1.
    • Use the spudger tool remove the plastic covers on the four corners of the display.
    • If this is the first time they are being removed they will be held in place by glue. Some force may be required.
    FixBot'a Sor
    Yorum Ekle
  27. Sony VAIO VPC-EB33FM Display Replacement: adım 27, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the four 5.75-mm screws under the plastic covers.
    FixBot'a Sor
    Yorum Ekle
  28. Sony VAIO VPC-EB33FM Display Replacement: adım 28, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 28, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement: adım 28, 3 resimden 3.
    • Use the plastic opening tool to separate the plastic front cover by wedging the tool along the seam.
    • Flip the laptop to the other side. If the front cover is still attached continue using the plastic opening tool to separate.
    • Carefully lift up the display. Completely detach the front plastic cover.
    FixBot'a Sor
    Yorum Ekle
  29. Sony VAIO VPC-EB33FM Display Replacement: adım 29, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the four 5.65-mm screws on each bottom corner of the display.
    FixBot'a Sor
    Yorum Ekle
  30. Sony VAIO VPC-EB33FM Display Replacement: adım 30, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 30, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement: adım 30, 3 resimden 3.
    • Do not pull too hard to avoid damage to the connections.
    • Gently lift and pull the LCD screen up. The back of the screen has a connection attached by yellow tape.
    • Holding the silver flap underneath the yellow tape, pull up and disconnect the wire.
    • Place the LCD screen aside.
    FixBot'a Sor
    Yorum Ekle
  31. Sony VAIO VPC-EB33FM Display Replacement: adım 31, 1 resimden 1.
    • Grab a hold of the black plastic hinge and pull out completely.
    • Repeat for the other side.
    FixBot'a Sor
    Yorum Ekle
  32. Sony VAIO VPC-EB33FM Display Replacement: adım 32, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 32, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 3.15-mm screws at top of the display.
    FixBot'a Sor
    Yorum Ekle
  33. Sony VAIO VPC-EB33FM Display Replacement: adım 33, 3 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 33, 3 resimden 2. Sony VAIO VPC-EB33FM Display Replacement: adım 33, 3 resimden 3.
    • Use the plastic opening tool to gently fold back all metal flaps at the beginnings and ends of wires.
    • Remove the tape holding a thin black and gray wire in place.
    FixBot'a Sor
    Yorum Ekle
  34. Sony VAIO VPC-EB33FM Display Replacement: adım 34, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a plastic opening tool to loosen and remove the two connections at the top end of the wire with a thick silver covering.
    • Metal tweezers may also be used to remove the connections.
    FixBot'a Sor
    Yorum Ekle
  35. Sony VAIO VPC-EB33FM Display Replacement: adım 35, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 35, 2 resimden 2.
    • Carefully pull the webcam and to remove it.
    • Fold back the metal flap under the webcam with the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  36. Sony VAIO VPC-EB33FM Display Replacement: adım 36, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 36, 2 resimden 2.
    • Pull back the silver tape attaching the gray wire.
    FixBot'a Sor
    Yorum Ekle
  37. Sony VAIO VPC-EB33FM Display Replacement: adım 37, 2 resimden 1. Sony VAIO VPC-EB33FM Display Replacement: adım 37, 2 resimden 2.
    • Pull back the silver tape attaching the black wire
    FixBot'a Sor
    Yorum Ekle
  38. Sony VAIO VPC-EB33FM Display Replacement: adım 38, 1 resimden 1.
    • Remove the bottom cover.
    • The laptop is now fully detached from the display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Angelica Ramirez
138 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-39, Regan Winter 2013 Cal Poly, Team 18-39, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G39
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 6,301
