Ana içeriğe geç
Sony VAIO VPC-EB33FM Hard Drive Replacement
Neye ihtiyacın var
  1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 2, 1 resimden 1.
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 3, 2 resimden 1. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 5, 3 resimden 1. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 5, 3 resimden 2. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 5, 3 resimden 3.
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 7, 1 resimden 1.
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 8, 2 resimden 1. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 8, 2 resimden 2.
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  9. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 9, 2 resimden 1. Sony VAIO VPC-EB33FM Hard Drive Replacement: adım 9, 2 resimden 2.
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Christian
195 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-39, Regan Winter 2013 Cal Poly, Team 18-39, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G39
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 18,544
