Ana içeriğe geç
Sony VAIO VPC-EB33FM RAM Replacement
Neye ihtiyacın var
  1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM RAM Replacement: adım 2, 1 resimden 1.
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM RAM Replacement: adım 3, 2 resimden 1. Sony VAIO VPC-EB33FM RAM Replacement: adım 3, 2 resimden 2.
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM RAM Replacement, RAM: adım 4, 3 resimden 1. Sony VAIO VPC-EB33FM RAM Replacement, RAM: adım 4, 3 resimden 2. Sony VAIO VPC-EB33FM RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  5. Sony VAIO VPC-EB33FM RAM Replacement: adım 5, 2 resimden 1. Sony VAIO VPC-EB33FM RAM Replacement: adım 5, 2 resimden 2.
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  6. Sony VAIO VPC-EB33FM RAM Replacement: adım 6, 3 resimden 1. Sony VAIO VPC-EB33FM RAM Replacement: adım 6, 3 resimden 2. Sony VAIO VPC-EB33FM RAM Replacement: adım 6, 3 resimden 3.
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bret Omsberg
16 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-39, Regan Winter 2013 Cal Poly, Team 18-39, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G39
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
when i press the power button in VAio still black screen with little tick sound,
and one day i just turn it on and leave it for 17 hours and sadnlley it worked but when i tried to restart it it still not working with tick tick tick tick sound !!! any advise !!!?
dorii135 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 4,440
