Ana içeriğe geç
Sony VAIO VPCEE26FX Optical Drive Replacement
Neye ihtiyacın var
    1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
      • Ensure that the laptop is powered off before disconnecting the battery.
      • Flip the laptop over so the underside of the laptop is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 2, 2 resimden 1. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 2, 2 resimden 2.
      • Slide the two tabs towards each other until the battery disconnects slightly from its position.
      • Carefully lift the battery out of its position away from the laptop.
      • The battery is not pictured here, since it is missing from this particular device.
      FixBot'a Sor
      Yorum Ekle
    1. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
      • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
      FixBot'a Sor
      Yorum Ekle
    2. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 4, 2 resimden 1. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 4, 2 resimden 2.
      • Remove the optical drive gently away from its holder on the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Christopher Hover
679 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G3
3 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 845
