Ana içeriğe geç
Sony VAIO VPCEE26FX Optical Drive Replacement
Neye ihtiyacın var
  1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 2, 2 resimden 1. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 2, 2 resimden 2.
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
  4. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 4, 2 resimden 1. Sony VAIO VPCEE26FX Optical Drive Replacement: adım 4, 2 resimden 2.
    • Remove the optical drive gently away from its holder on the laptop.
Sonuç
Christopher Hover
679 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 438
