Ana içeriğe geç
Sony Vaio Duo 11 SSD Replacement
Neye ihtiyacın var
  1. Sony Vaio Duo 11 SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Make a system backup!
  2. Sony Vaio Duo 11 SSD Replacement: adım 2, 2 resimden 1. Sony Vaio Duo 11 SSD Replacement: adım 2, 2 resimden 2.
    • Using a spudger, remove the rubber screw covers.
    • Gently remove the speaker covers.
  3. Sony Vaio Duo 11 SSD Replacement: adım 3, 1 resimden 1.
    • Use a sharp tool to lift up the laptop's cover
  4. Sony Vaio Duo 11 SSD Replacement: adım 4, 1 resimden 1.
    • Remove cover
  5. Sony Vaio Duo 11 SSD Replacement: adım 5, 1 resimden 1.
    • Remove all the screws. (Attention: these screws are different! Save them.)
  6. Sony Vaio Duo 11 SSD Replacement: adım 6, 2 resimden 1. Sony Vaio Duo 11 SSD Replacement: adım 6, 2 resimden 2.
    • Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
    • Remove the screws (circled in red) and remove the battery.
    • When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
  7. Sony Vaio Duo 11 SSD Replacement: adım 7, 1 resimden 1.
    • Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
  8. Sony Vaio Duo 11 SSD Replacement: adım 8, 1 resimden 1.
    • Remove these screws to make it easier to remove the SSD.
  9. Sony Vaio Duo 11 SSD Replacement: adım 9, 1 resimden 1.
    • The remove of the ssd
    • Remove the SSD (gently)
    • Replace the SSD ( it is a mSATA SSD )
    • Put back the screws and close the unit
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Zero
880 İtibar
1 Kılavuz yazıldı
14Kılavuz Yorumları
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
Anwar - Yanıt
1TB ssd here I come!!!!
jamice4u - Yanıt
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
scorpiotide - Yanıt
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Nathan Price - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 65
Her zaman: 41,705
