Aletler
Parçalar
Hiçbir parça belirtilmedi.
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
Lift off back cover to access inner components of computer.
Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
Remove the battery with the Plastic Opening Tool by placing the tool between the battery and the computer and cautiously prying it out.
2 farklı kişi bu kılavuzu tamamladı.
