Ana içeriğe geç
Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
Neye ihtiyacın var
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: adım 2, 1 resimden 1.
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: adım 3, 2 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: adım 3, 2 resimden 2.
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: adım 4, 1 resimden 1.
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: adım 5, 2 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Olivia
605 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 58
Her zaman: 3,813
