Giriş
If your Sony Vaio Fit 13A ( model SVF13NA1EL) is making excessive noise or is getting too warm, as described in the troubleshooting page for this laptop, the problem may be caused by a dirty or broken fan. This guide will show you how to open your laptop and clean the fan. If cleaning does not fix the problem then this guide will also show how to replace the fan.
Before beginning make sure the laptop is powered off.
Neye ihtiyacın var
Begin by laying the laptop top-down on a flat surface.
Use a JIS #1 screwdriver to remove the 4 screws circled in red from the back cover.
Use a JIS #0 screwdriver to remove the 8 screws circled in orange.
Bir başkası bu kılavuzu tamamladı.
