Ana içeriğe geç
Sony Vaio Fit 13A SVF13NA1EL Screen Connector
Neye ihtiyacın var
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 1, 1 resimden 1.
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 2, 3 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 2, 3 resimden 2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 2, 3 resimden 3.
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 3, 1 resimden 1.
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 4, 1 resimden 1.
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 5, 2 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: adım 5, 2 resimden 2.
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Olivia
605 İtibar
5 adet Kılavuz yazıldı
5 Yorum
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - Yanıt
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - Yanıt
Where i buy flexi
msobirin48 - Yanıt
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - Yanıt
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 4,158
