Ana içeriğe geç
Sony Vaio Fit 13A SVF13NA1EL Screen Replacement
Neye ihtiyacın var
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement, Screen: adım 1, 2 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Unlock the screen and flip it so that the screen is in tablet mode.
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 2, 1 resimden 1.
    • Looking at the back of the screen, remove all 8 screws using a Phillips #0
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 3, 3 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 3, 3 resimden 2. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 3, 3 resimden 3.
    • Use a plastic spudger to carefully remove the back cover of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 4, 1 resimden 1.
    • Reveal internal screen components
    • Remove all 10 screws
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 5, 2 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 5, 2 resimden 2.
    • Carefully remove each end of the connector strip from the back panel.
    • Make sure to flip the white portions of the chips for easy release from the LCD connector.
    • Feed the disconnected ribbon highlighted in blue through the slot in the metal frame.
    • Disconnect section of the screen connector highlighted in blue.
  6. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 6, 2 resimden 1. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 6, 2 resimden 2.
    • Gently pull up on the tape at the bottom of the ribbon to unplug the screen connector from the screen.
  7. Sony Vaio Fit 13A SVF13NA1EL Screen Replacement: adım 7, 1 resimden 1.
    • The screen can now be removed and replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Olivia
605 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 51
Her zaman: 3,525
