Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
Lift off back cover to access inner components of computer.
Use a pair of tweezers to gently disconnect the two antenna cables.
Locate and remove the single 1mm Phillips #0 screw that is securing the wireless card to the motherboard.
Gently grasp wireless card with two fingers and pull away from motherboard to the left.
