Ana içeriğe geç
Sony Vaio Fit SVF14A190X Battery Replacement
Neye ihtiyacın var
  1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 2, 3 resimden 1. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 2, 3 resimden 2. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 3, 3 resimden 1. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 3, 3 resimden 2. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 4, 2 resimden 1. Sony Vaio Fit SVF14A190X  Battery Replacement: adım 4, 2 resimden 2.
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Randal Crosby
187 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G3
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 1,853
