Giriş
This is an easy to follow, step by step guide to help aid in the replacement of the RAM for a Sony Vaio Fit SVF14A190X. The RAM is an important component that stores memory.
Use the Phillips head screw driver to remove the eleven 6 mm screws.
Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
The RAM is a small rectangular component located on the opposite side of the lab top from where you pulled out the CD disc drive.
Bir başkası bu kılavuzu tamamladı.
