Ana içeriğe geç
Giriş
The Sony Vaio Fit SVF15N26CXB has a flip screen that makes it different from a regular screen to remove. This guide will show you the necessary steps to take to replace the display. Use the project mat to keep the screws organized.
  1. Remove the following ten screws from the bottom case of the laptop: Two 6.5mm Phillips #00 Phillips screws.
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Use a plastic opening tool to separate the bottom cover from the laptop. Lift the lower cover and pull away from the laptop.
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Remove the eight Phillips #00 screws from the battery: Six 4.65mm screws. Two 4.65mm screws.
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Lift the battery up and pull it out of the laptop.
    • Lift the battery up and pull it out of the laptop.
  5. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  6. Open the laptop and rotate the screen to the back side.
    • Open the laptop and rotate the screen to the back side.
    • Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
  7. Rotate the screen back and close the laptop. Use a plastic opening tool to carefully pry up the back plastic case.
    • Rotate the screen back and close the laptop.
    • Use a plastic opening tool to carefully pry up the back plastic case.
    • Remove the back plastic case by sliding it down and pulling upwards.
  8. Remove the thirteen 2.85mm Phillips #00 screws from the screen. Remove the thirteen 2.85mm Phillips #00 screws from the screen.
    • Remove the thirteen 2.85mm Phillips #00 screws from the screen.
  9. Use a spudger to lift up the black latch on the ZIF connector. Pull the display ribbon cable out of the ZIF connector. Pull the display ribbon cable out of the ZIF connector.
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Pull the display ribbon cable out of the ZIF connector.
  10. Remove the display cable peeling up the tape. The display cable locking mechanism is attached to the tape. The display cable locking mechanism is attached to the tape.
    • Remove the display cable peeling up the tape.
    • The display cable locking mechanism is attached to the tape.
  11. Remove the display.
    • Remove the display.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Althea McDavid
730 İtibar
6 adet Kılavuz yazıldı
Takım
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 10
Son 30 Gün: 35
Her zaman: 466
