Ana içeriğe geç
Sony Vaio Fit SVF15N26CXB Speaker Replacement
Neye ihtiyacın var
  1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 2, 2 resimden 1. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 3, 3 resimden 1. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 3, 3 resimden 2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 3, 3 resimden 3.
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 4, 1 resimden 1.
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: adım 5, 3 resimden 1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: adım 5, 3 resimden 2. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • Remove six 5.75mm Phillips #00 screws from the speakers.
  6. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 6, 3 resimden 1. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 6, 3 resimden 2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 6, 3 resimden 3.
    • Use a spudger to flip up the black latch on the four ZIF connectors.
    • Remove the four ribbon cables from the ZIF connectors.
    • Disconnect the speaker from the board.
  7. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 7, 2 resimden 1. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
    • Where the wire is stuck under tape, gently pull the tape up until the wire is free.
    • Do not remove the tape.
  8. Sony Vaio Fit SVF15N26CXB Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Althea McDavid
857 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 492
