Giriş
If your computer in running slow it may be due to a hard drive error. This guide will show you how to replace the hard drive in your Sony Vaio PCG-16L.
Neye ihtiyacın var
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
Bir başkası bu kılavuzu tamamladı.
