Ana içeriğe geç
Sony Vaio PCG-161L Speakers Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-161L Speakers Replacement, Keyboard: adım 1, 1 resimden 1.
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Speakers Replacement: adım 2, 2 resimden 1. Sony Vaio PCG-161L Speakers Replacement: adım 2, 2 resimden 2.
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Speakers Replacement: adım 3, 2 resimden 1. Sony Vaio PCG-161L Speakers Replacement: adım 3, 2 resimden 2.
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Speakers Replacement, Speakers: adım 4, 1 resimden 1.
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Speakers Replacement: adım 5, 1 resimden 1.
    • Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
  6. Sony Vaio PCG-161L Speakers Replacement: adım 6, 1 resimden 1.
    • Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
  7. Sony Vaio PCG-161L Speakers Replacement: adım 7, 1 resimden 1.
    • Remove the top casing by lifting up on the plastic exposing the two speakers.
  8. Sony Vaio PCG-161L Speakers Replacement: adım 8, 1 resimden 1.
    • Remove the two 4 mm screws attaching the broken speaker to the casing.
    • Each speaker has two 4mm screws holding it to the casing. If you are removing both speakers, remove all four screws.
  9. Sony Vaio PCG-161L Speakers Replacement: adım 9, 1 resimden 1.
    • Disconnect the wire from the board by pulling the wire out of the harness.
    • These harnesses do not have any clips or tabs. Simply pull on the wire and it will come out of the harness.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Roman Alshehri
407 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 UMass Dartmouth, Team S3-G2, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G2
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 319
