Ana içeriğe geç
Sony Vaio PCG-31311L Keyboard Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-31311L Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Sony Vaio PCG-31311L Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Keyboard Replacement: adım 2, 2 resimden 1. Sony Vaio PCG-31311L Keyboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Keyboard Replacement: adım 3, 1 resimden 1.
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Keyboard Replacement: adım 4, 3 resimden 1. Sony Vaio PCG-31311L Keyboard Replacement: adım 4, 3 resimden 2. Sony Vaio PCG-31311L Keyboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Keyboard Replacement: adım 5, 3 resimden 1. Sony Vaio PCG-31311L Keyboard Replacement: adım 5, 3 resimden 2. Sony Vaio PCG-31311L Keyboard Replacement: adım 5, 3 resimden 3.
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
Sonuç
Tyler
45 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 543
