Ana içeriğe geç
Sony Vaio PCG-31311L Motherboard Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: adım 1, 2 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: adım 2, 2 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: adım 3, 1 resimden 1.
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: adım 4, 3 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement: adım 4, 3 resimden 2. Sony Vaio PCG-31311L Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: adım 5, 3 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement: adım 5, 3 resimden 2. Sony Vaio PCG-31311L Motherboard Replacement: adım 5, 3 resimden 3.
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: adım 7, 2 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement: adım 7, 2 resimden 2.
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: adım 8, 3 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement: adım 8, 3 resimden 2. Sony Vaio PCG-31311L Motherboard Replacement: adım 8, 3 resimden 3.
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: adım 9, 2 resimden 1. Sony Vaio PCG-31311L Motherboard Replacement: adım 9, 2 resimden 2.
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler
45 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,595
