Neye ihtiyacın var
Start with device closed, powered off, and upside down.
Locate 3 screws on the bottom plate and unscrew
Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
Bir başkası bu kılavuzu tamamladı.
