Ana içeriğe geç
Sony Vaio PCG-31311L RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-31311L RAM Replacement, RAM: adım 1, 2 resimden 1. Sony Vaio PCG-31311L RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew.
    • These screws do not detach from the plate.
  2. Sony Vaio PCG-31311L RAM Replacement: adım 2, 2 resimden 1. Sony Vaio PCG-31311L RAM Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry up on the bottom plate.
    • Lift up and away from the device.
  3. Sony Vaio PCG-31311L RAM Replacement: adım 3, 2 resimden 1. Sony Vaio PCG-31311L RAM Replacement: adım 3, 2 resimden 2.
    • Locate the 2 clips on either side of the RAM chip.
    • Push both of them out and away from the RAM chip. The RAM chip should pop up.
    • Slowly remove the chip from the device
    • Make note of which side the slot is on in order to correctly reinstall the RAM chip.
  4. Sony Vaio PCG-31311L RAM Replacement: adım 4, 2 resimden 1. Sony Vaio PCG-31311L RAM Replacement: adım 4, 2 resimden 2.
    • Repeat Step 3 on the other RAM chip
Sonuç
Tyler
45 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 952
