Ana içeriğe geç
Sony Vaio PCG-3C2L Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-3C2L Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 2, 2 resimden 1. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 2, 2 resimden 2.
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 3, 1 resimden 1.
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 4, 3 resimden 1. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 4, 3 resimden 2. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 4, 3 resimden 3.
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 7, 2 resimden 1. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 7, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 8, 3 resimden 1. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 8, 3 resimden 2. Sony Vaio PCG-3C2L Hard Drive Replacement: adım 8, 3 resimden 3.
    • Remove the hard drive by carefully sliding it out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 736
