Ana içeriğe geç
Sony Vaio PCG-41216L Battery Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-41216L Battery Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio PCG-41216L Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Battery Replacement: adım 2, 3 resimden 1. Sony Vaio PCG-41216L Battery Replacement: adım 2, 3 resimden 2. Sony Vaio PCG-41216L Battery Replacement: adım 2, 3 resimden 3.
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Battery Replacement: adım 3, 3 resimden 1. Sony Vaio PCG-41216L Battery Replacement: adım 3, 3 resimden 2. Sony Vaio PCG-41216L Battery Replacement: adım 3, 3 resimden 3.
    • Remove the battery cover and set it aside. Carefully remove the non-functioning battery and insert the new battery in its place.
    • Make sure to reattach the battery in the right position with the power port, so that the power connector lines up with the battery’s port.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,107
