Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
Pull the bottom plate towards yourself until it unhinges fully.
Once the plate is free from the backing remove it completely.
Look for the blue tab that is located to the bottom left of the battery.
Pull the blue tab towards yourself until you hear a click.
Once the blue tab is released, pull up on the battery.
Once the battery can move freely, take it out completely.
Remove seven 3mm Phillips #0 screws from the bottom of the computer.
Remove eight 5mm Phillips #0 screws.
Remove the three 2mm Phillips #00 screws located on the top right edge.
Gently pull apart the top and bottom plastic bodies.
Carefully remove the cable connectors.
Pull apart your device and set aside the screen of your laptop.
Locate the AUX Board in the top right of the computer body.
Remove the 2mm Phillips #0 screw.
Carefully pull the cable connector out to the left.
Once both are no longer connected remove the AUX Board completely.
2 farklı kişi bu kılavuzu tamamladı.
