Ana içeriğe geç
Sony Vaio PCG-4121GL SD Card Board Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-4121GL SD Card Board Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 2, 3 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 2, 3 resimden 2. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 2, 3 resimden 3.
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 3, 1 resimden 1.
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 4, 3 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 4, 3 resimden 2. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 4, 3 resimden 3.
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL SD Card Board Replacement, SD Card Board: adım 5, 2 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement, SD Card Board: adım 5, 2 resimden 2.
    • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
    • Remove eight 5mm Phillips #0 screws.
  6. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 6, 3 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 6, 3 resimden 2. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 6, 3 resimden 3.
    • Carefully remove the disk drive from its compartment.
  7. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 7, 2 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 7, 2 resimden 2.
    • Remove the three 2mm Phillips #00 screws located on the top right edge.
  8. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 8, 2 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 8, 2 resimden 2.
    • Gently pull apart the top and bottom plastic bodies.
    • Carefully remove the cable connectors.
    • Slowly detach bottom component to avoid tearing wires/connectors.
  9. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 9, 3 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 9, 3 resimden 2. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 9, 3 resimden 3.
    • Pull apart your device and set aside the screen of your laptop.
    • Locate the SD Card Board in the bottom left of the computer body.
  10. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 10, 2 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 10, 2 resimden 2.
    • Remove the cables from their connectors.
    • Do not apply too much force to the cable connectors or they may tear.
  11. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 11, 2 resimden 1. Sony Vaio PCG-4121GL SD Card Board Replacement: adım 11, 2 resimden 2.
    • Lightly press down on the bottom left corner of the plastic frame.
    • Pull SD Board out towards you once it feels loose.
    • Once the SD Board is free from the plastic, remove completely
    • The SD Card slot is shown.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryce McNeil
391 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G2, White Winter 2019 Cal Poly, Team S2-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S2G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 869
